6Aussies
Oct 01, 2020Aspirant
Wireless login to router
I'm trying to wirelessly login to my R6300v2 router. When I enter "routerlogin.net" on the web page, it either displays a page saying "You may not be connected to your routers WiFi" or it will displa...
- Oct 01, 2020
> [...] "You may not be connected to your routers WiFi" [...]
That's usually a DNS (and/or browser+DNS) problem:
https://community.netgear.com/t5/x/x/m-p/1976674
> [...] I'm certain I am entering the correct login info (case and
> content) . [...]With my weak psychic powers, I couldn't say. Perhaps the router
disagrees. A settings reset should restore the default credentials,
which should remove any doubt about their correctness. (See the product
label.)Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "Types of Logins" and
"Factory Settings".
antinode
Oct 01, 2020Guru
> content) . [...]
label.)
"Factory Settings".
- 6AussiesOct 02, 2020Aspirant
Yeah I was afraid I'd have to do that. I'm sure that will "clear" whatever problem with credentials exists, just thought maybe I was missing something obvious with my procedure. I'll give it a shot when the wife and daughter aren't home so I don't suffer more....;<{
