Bowa
Sep 11, 2019Aspirant
Wireless-N Router Model WNR2000, restarts then and then
I have got a router, Netgear WNR2000, which have been running for some years. It suddenly started to behave strange, it seems to restart suddenly, often comes back after a while but sometime it just...
- Sep 19, 2019
All firmware updates for your router are on the support page that gave you the first one.
If you visit the support pages:
you can feed in the model number and find all the documentation for your hardware.
There is no V1.1.5.5 for the WNR2000 (V1), so I can't telll you which page to go to.
There are five different versions of this device. You need to pick the right one. Look at the label on the thing.
Sep 11, 2019Guru - Experienced User
You can just update to the latest version. Make sure to do it over a hardwired connection. I'd also recommend resetting back to factory after the update. Tends to have the best results.
It could be multiple things causing the drops. that router specifially was released in 2008. in 11 year old devices it could be power supply being bad, it could be main board bad, wireless board bad. or it could be modem issues. so we'll need to figure out first if its modem or router and then troubleshoot from there.
What modem are you using?
If you're only wired into the modem (no router) do you get the same drops?
How frequently are you getting the drops?
Is it only wireless devices that go down or wired and wireless?
Bowa
Thanks for the reply
I will update the firmvare asap
The interesting thing is that it loses the connection much more during daytime, couple times per hour, then during evenings, during evenings it's quiet stable. This could perhaps been going on for while since I normally is not at home connecting during daytime but have working from home some weeks.
Both Wired and WIFI goes, I sometimes got a feeling that could it starts with a wifi connection with a new SAMSUNG tablets but it is not always. I have not been able to pin-point in which situation it goes down.
I will update the firmware to see if that "solves" anything otherwise it seems to be a good idea to replace the router
