Bowa's avatar
Bowa
Wireless-N Router Model WNR2000, restarts then and then
I have got a router, Netgear WNR2000, which have been running for some years. It suddenly started to behave strange, it seems to restart suddenly, often comes back after a while but sometime it just...
  • michaelkenward's avatar
    Sep 19, 2019
    All firmware updates for your router are on the support page that gave you the first one.
    If you visit the support pages:
    Support | NETGEAR
    you can feed in the model number and find all the documentation for your hardware.
    There is no V1.1.5.5 for the WNR2000 (V1), so I can't telll you which page to go to.
    There are five different versions of this device. You need to pick the right one. Look at the label on the thing.
