Bowa
Sep 11, 2019Aspirant
Wireless-N Router Model WNR2000, restarts then and then
I have got a router, Netgear WNR2000, which have been running for some years. It suddenly started to behave strange, it seems to restart suddenly, often comes back after a while but sometime it just...
- Sep 19, 2019
All firmware updates for your router are on the support page that gave you the first one.
If you visit the support pages:
you can feed in the model number and find all the documentation for your hardware.
There is no V1.1.5.5 for the WNR2000 (V1), so I can't telll you which page to go to.
There are five different versions of this device. You need to pick the right one. Look at the label on the thing.
michaelkenward
Sep 12, 2019Guru - Experienced User
Bowa wrote:
The router is running an old version of firmware, can I just update to last version or do I have to update
Do as plemans says. That works nine times out of ten, probably more, but there are rare circumstances when you need to go through an intermediate stage.
If a direct update doesn't work, go for somewhere in the middle until that sticks and then apply the latest.
Bowa
Sep 19, 2019Aspirant
I updated to the latest version without any problem. I'm not yet conviced that it lsoved my problem, running it to short time
But anyhow,
Now it states that should upgrade Language Table Upgrade Assistant & Firmware Upgrade Assistant from V1.1.5.5 to V1.1.5.12, so I thought Ok but I can't find this update ?
Any hint's where to find it ?
- michaelkenwardSep 19, 2019Guru - Experienced User
