crystalfanning1's avatar
May 10, 2016
wireless not working. model wndr3700v2
We have this router and it's kind of old..2011 model wndr3700v2. We've never had problems with it until tonight. It says "internet unavailable for netgear" my phone will connect to the internet, but a...
  • crystalfanning1's avatar
    crystalfanning1
    May 15, 2016
    Yeah when I called support, they said it was most likely a problem with my ip address instead of my router. I don't know if it was just the weather or what, but we had this problem for 3 nights in a row, and all 3 nights we had rain, wind, etc. And since then it has been fine. I do have a desktop computer but it isn't a wired connection, they are on different levels of the house. All wireless connectivity was down/unavailable, and then the very next morning would be back up. And since we've never had any problems before, I would guess it was due to the weather..although at the time I just thought our router was going out or losing connection. I appreciate the suggestions and help, but I think it's solved! Thank you!
