Openid
May 09, 2025Follower
Wireless Repeating Function is not available
 Good day, everyone.     In 2025 I dug up kinda old Netgear WNR3500L v2. I wish to use it as a wireless repeater with my actual router so I can connect via Ethernet devices, those are too far from my ...
May 12, 2025Guru - Experienced User
Before you dive too deep into anything, remember, the WNR3500L is a 15-year-old device that had pretty anemic N300 specs. It wasn't a very fast device to start with. In bridge mode, those speeds get cut in half as it can't broadcast/receive at the same time. Compared to anything from this generation or even last generation's half-decent extenders, it's going to be extremely slow. Unless you're using it for a few simple IoT devices that are low bandwidth, you're better off recycling it and picking up a half decent extender or even a router and wiring it in running in access point mode.
So what are you using it for?
frugson
Aug 03, 2025Aspirant
Totally fair point I’m mainly using it just to hook up a couple of old devices via Ethernet, nothing bandwidth-heavy.
