mtdial's avatar
mtdial
Follower
Jan 11, 2017
Wireless router setup without modem
Question regarding the N600 (WNDR3400) wireless dual band router. We are full time Rvers and have no modem. We utilize only wireless networks such as campground signals and personal hotspots. Without...
  • StephenB's avatar
    Jan 11, 2017
    The WNDR3400 can serve as a repeater, but only the main network has security turned off.
    A router that supports WISP operation (able to use WiFi as an "internet port") might be better suited to what you have in mind.
    Many travel routers support WISP.  I use a TP-Link TL-WR802N for this myself when I travel (Netgear doesn't have an equivalent).  https://www.amazon.com/TP-LINK-TL-WR802N-Wireless-Repeater-300Mbps/dp/B00TQEX8BO/
    It is very small, can be powered by any USB charger, and is pretty easy to connect to a new WiFi network.
    And since it is a NAT router, it will isolate your devices from other folks using the same campground/hotspot.
    It can also be configured as a repeater if you want that, but I find the two router modes to be most useful (ethernet internet port and WISP)
