hendja
Sep 16, 2015Aspirant
Wireless router
I have had a N900 wireless router for 3 months. It ran out of tech support one week ago and quit connecting to wireless then. I called Tech Support and they did some testing and said that there was...
- Sep 19, 2015Everything is working great!
ElaineM
Sep 17, 2015NETGEAR Employee Retired
Hello hendja,
Welcome to the community!
Do you have internet access when you direct connect your computer directly to the modem?
Are you just having trouble with the wireless connection?
Try to see if this link would help get you back online.
Let us know what happens.
hendja
Sep 17, 2015Aspirant
P>S> Elaine--I do have internet access when I plug my modem directly into my computer. I am just having trouble with the wireless router.
- ElaineMSep 18, 2015NETGEAR Employee Retired
hendja Check this link on how to get into the router settings. I assume that when you say wireless router that means whole router not just the wireless portion of the router. If that's the case, reset the router by pushing the reset button on the router for 10 seconds. After reset, follow the instructions that was given previously to reconfigure the router.
Looking forward to your response.
- hendjaSep 18, 2015Aspirant
Elaine--I finally got into routerlogin.net and looked at everything. I actually reset my factory defaults. I reinstalled Netgear Genie. She keeps telling me that my Wireless Adapter is not turned on on my computer. I have no idea--I have searched on my computer but can't find that anywhere. I am about to give up. I am so frustrated.
Elaine--You won't believe what I finally found. I had hit the F2 key and turned the wireless off on my laptop. Thanks for trying so hard to help me. :(
