ankit96barthwal
Jul 26, 2016Aspirant
Wireless Signal Drop
Hi, my Netgear wndr4500v3 is constantly dropping signal every hour. the internet and power indicators remain constant however the indicator on 2.5ghz and 5ghz signs goes off every couple of hours, I...
- Jul 26, 2016
ankit96barthwal Normally, this should be fixed by firmware upgrade.
Since you already updated the firmware and have done reset maybe it's time to get a new router.
ankit96barthwal
but how, can't it be fixed
ElaineM
Jul 26, 2016NETGEAR Employee Retired
