rrwilson2's avatar
rrwilson2
Wireless turning itself off
 got a new tablet today and I couldn't get it to connect to the wireless router. now my kindle won't either. no signal is found by either tablet. the wireless has turned off and I can't get it back o...
  • ElaineM's avatar
    ElaineM
    Aug 25, 2017
    The orientation of your router might be different from the one that I might be thinking.
    But for clarity, do you see lights on 2.4GHz and 5GHz?
    If you already have pushed the reset button and if those lights are still off then you might have a bad router.
    Possible that the wireless portion of it got busted.
