rrwilson2
Aug 23, 2017Aspirant
Wireless turning itself off
got a new tablet today and I couldn't get it to connect to the wireless router. now my kindle won't either. no signal is found by either tablet. the wireless has turned off and I can't get it back o...
- Aug 25, 2017
The orientation of your router might be different from the one that I might be thinking.
But for clarity, do you see lights on 2.4GHz and 5GHz?
If you already have pushed the reset button and if those lights are still off then you might have a bad router.
Possible that the wireless portion of it got busted.
ElaineM
Aug 24, 2017NETGEAR Employee Retired
Welcome to the community, rrwilson2
What lights are lit on the router?
Just to verify, what's the exact model number of the NETGEAR router?
Did you try to factory reset the router?
rrwilson2
Aug 24, 2017Aspirant
yes, I did a factory reset.
- ElaineMAug 25, 2017NETGEAR Employee Retired
- rrwilson2Aug 25, 2017Aspirant
thanks. no I don't have those lights showing.
I think it's shot. I realized things had been acting up, it's coincidence that I tried to hook up with my new tablet ad it died st about the same time.
- ElaineMAug 28, 2017NETGEAR Employee Retired
It's now time to get a new one. :)
Have a great day!
