WATCH_IT_BUSTER
Mar 28, 2023Initiate
WN2500RPv2 as an access point
I have been using this product as a WIFI extender for years without any issues. At a new location I set this unit up as an access point instead of a WIFI extender. I did a factory reset then follo...
- Mar 28, 2023I'm not sure about your device, but on a lot of recent routers & co orange indicates a 100 Mbps instead of 1 Gbps connection.
microchip8
Mar 28, 2023Master
- michaelkenwardMar 28, 2023Guru - Experienced User
microchip8 wrote:
I'm not sure about your device, but on a lot of recent routers & co orange indicates a 100 Mbps instead of 1 Gbps connection.The data sheet and manual for the WN2500RPv2 say that its has "fast ethernet". That is 100 Mbps.
But that does not explain the power LED. That could be down to problems with the power adapter.
This thing dates from 2016, with its V1 release in 2012.
Regardless of any claims it makes for WiFi speed (up to 600 Mbps?), it won't connect devices to the Internet at anything above 100 Mbps.
- WATCH_IT_BUSTERMar 29, 2023Initiate
Thanks for the advice.
I think I will ignore the light for now as I am using this for cell phone internet access and my phone is not 5G.
Once I get a 5G phone I think it will be time for a new access point.
