MickeyFlint
Apr 06, 2021Follower
WN2500RPv2 Factory reset now wont see http://mywifiext
So I moved and wanted to reset this up after having used it a few years at my old place. I did the push button factory reset on it and now (as per the setup guide) have connected both wirelessly and ...
Apr 06, 2021Guru - Experienced User
Try this.
Factory reset it 1 more time.
Push and hold reset for 7-15 seconds while its powered on.
Then during setup, hardwire a pc/laptop into it. Disable the wifi on the pc/laptop to ensure it doesn't default back to the wifi.
Then try the mywifiext . net (take the spaces out) or try 192.168.1.250 (default ip address)
