Mizmelzy76
Aug 15, 2022Tutor
WN3000RP Reset and can't connect
A friend had Given Me Their WN3000RP extender. I am Trying To Set It Up As A Temporary Fix For Internet As My Room The Wifi Doesn't Extend That Far. The Router I Had To Extend Is Having Issues So Tho...
michaelkenward
Aug 16, 2022Guru - Experienced User
It is very hard to follow your messages. There just isn't much useful information.
What router are you trying to connect it to?
Just about the only clue we have to what is happening is when you write:
Mizmelzy76 wrote:
I Can Find It On The Computer But It Will Not Let Me Connect To It At All.
What happens when you try?
Be warned that the WN3000RP is an aged device. Don't expect a lot.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
