Kmmmn
Feb 05, 2023Aspirant
WN3000RP v3 N300 extender IPV6 disabling
Hi. Wondering if it’s possible to disable IPv6 on my N300 extender and if so, how. thanks, KM
Kmmmn
Feb 11, 2023Aspirant
i have a firestick and cannot disable ipv6 on it. I have ipv6 disabled on my router but it still shows on my FS. I wondered if I used my Netgear as an access point I could connect my FS to it, but only if I could set it up with ipv6 disabled. Thanks.
michaelkenward
Feb 12, 2023Guru - Experienced User
Same question as plemans really, why do you want to do that?
IPv6 is a newfangled thing that appeared after the WN3000RP from 2011.
Then there is the fact that the WN3000RP is a range extender. In that case, the router it extends is in charge of network management.
