dkkaspar
Jan 10, 2021Aspirant
WN3000RP Wont accept network password
I replaced my router, so I needed to reinstall this extender. I reset the extender to factory defaults, then worked throught the procedure for "connecting with WPS". The extender shows up on the list of available wireless networks, but when I attempt to login the extender does not accept the network password.
what router do you have now?
Have you tried factory resetting the extender and instalilng it using the installation assistant and not WPS?
Thats what I'd try
- dkkasparAspirant
I tried your suggestion, but I ran into the same problem. I'm using the Centurylink C1100T router.
> Model: WN3000RP|Universal WiFi Range Extender
Not WN3000RPv2 or WN3000RPv3? Look for "Model" on the product label.
> [...] I reset the extender to factory defaults, then worked throught
> the procedure for "connecting with WPS". [...]_Which_ 'the procedure for "connecting with WPS"'? Are you following
some set of instructions or other? Which you found where, exactly?> [...] The extender shows up on the list of available wireless
> networks, [...]_Which_ "the list of available wireless networks", where?
> [...] when I attempt to login [...]
"login" to what? From what? How?
> [...] the extender does not accept the network password.
Says who? When you do what, exactly? Are you reading some message
or other, someplace or other?_Which_ "the network password"? If you're using WPS, then what are
you doing with _any_ "the network password"? As the WN3000RP
Installation Guide says (page 6):WPS lets you easily join a secure Wi-Fi network without typing
the network name and password. [...]At least one of us is confused.
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Follow instructions? If questions or problems persist, then you might
return here with a precise, accurate description of what you did, and
what happened when you did it. (Not a vague mess about which
"procedure" you followed, and what did _not_ happen when you did
whatever you did.)> [...] I'm using the Centurylink C1100T router.
That seems to have a "WPS button". Did you use it?
https://www.centurylink.com/asset/home/help/downloads/internet/c1100t-datasheet.pdf
