dcook5
Oct 13, 2022Follower
WNA1100 Runtime error
WNA 1100 running on Windows 10. The adapter seems to work and connect to the internet. However recently I keep getting this error: "This application has requested the Runtime to terminate it in ...
Oct 13, 2022Guru - Experienced User
I'd uninstall the genie and all the software. Then just install the standalone driver. Windows can manage the wireless networks fine without netgears genie
- michaelkenwardOct 14, 2022Guru - Experienced User
Even better, for some USB adapters you don't even need to install Netgear's drivers.
The native drivers in Windows can do the job.
WiFi Adapters - NETGEAR Communities
You might like to search there for messages related to your problem.
