Sedis
Jul 27, 2022Aspirant
WNCE4004 corrupt firmware?
The unit is blinking red indicating "the firmware is corrupt. See the User Manual for instructions." However the user manual makes no further reference to the issue. Is anyone able to point me in t...
Jul 27, 2022Guru - Experienced User
You can try recovering it with nmrpflash or tftp. Not sure if it'll work as that device is from 2012.
MIght be worth upgrading because it might not just be a corrupt firmware but storage chip finally giving up.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
- SedisJul 27, 2022Aspirant
Thanks, I'll try that.
If it doesn't work, what would you suggest replacing it with? As you say it is quite old.
The device I can still connect to the internet on is a Mac as I was using the WNCE4004 to connect to my PC
- michaelkenwardJul 28, 2022Guru - Experienced User
That is an old (2012) device that Netgear no longer makes.
What was the WNCE4004 doing in the connection to your PC?
It was intended to provide a wifi to wired-Ethernet connection to things. These days you have several options. For example, you could replace the WNCE4004 with a wifi extender. Another option would be to use Powerline Ethernet to wire the PC to the router over the mains circuit.
This is guesswork on my part based on knowing next to nothing about the router you have and what else is on your network.
- SedisJul 28, 2022Aspirant
The PC was one provided by my work which was never intended to be used outside the office, so has no wi-fi. Since Covid it has been used at home. As I was already using the WNCE4004 to provide ethernet connection to some Hi-Fi equipment to provide internet radio, it seemed like the simplest solution at the time, especially as any PC equipment for working from home was in short supply.
I've seen that some current Wi-Fi extenders also have ethernet outputs, so I'll look into thoseThanks for the advice
