gregm1010
Jun 26, 2021Aspirant
Wnd 4500 no power
I have a wnd 4500 router. This morning the unit is dead. No power. Modem is plugged into same back power supply and has power. Even plugged into the outlet that the modem was in in case problem was th...
gregm1010
Thanks for the reply. The cord that plugs into the back of the router, will not come out. Needed to get back on line. Went to Best Buy and got a new updated router and am just finishing setting up all devices.
Jun 26, 2021Guru - Experienced User
eitherway glad you got something working.
is this the router you have?
https://www.netgear.com/support/product/WNDR4500.aspx
If so, the cord should be removable. If its not coming out for some reason (corrosin/fused/etc) , i wouldn't be messing with it to much unless you know what you're doing.
