Mz_G
Sep 06, 2022Aspirant
WNDR 3400 v3 is it IPv4
Hi! I have a NetGear N600 Wireless Dual Band Router. I'm trying to connect wifi extender. I get all the way through, but when I click "finish" it says "IP is dif. Than root AP. Extenders support said ...
Sep 07, 2022Guru - Experienced User
What extender you are connecting to it?
What firmware is on the router?
firmware on the extender?
What method of setup are you using on the extender? some use wps, some use a installation assistant
Mz_G
Sep 08, 2022Aspirant
Hi! I purchased one of Amazon. It's a EITTAR 300 Mbps Wifi Range Extender. Router Firmware is V1.0.046.1.0.45. Extender Firmware.…... Honestly, haven't a clue how to obtain this information. Setup method....it came with instructions and I just followed the prompts. One of reasons I was sold is because it was supposed to be a "1-Tap Setup". Ha! My parents taught me better, "If it's sounds too good to be true, it probably is". Yet, here I am. Grown and still hard headed.
