Mz_G
Sep 06, 2022Aspirant
WNDR 3400 v3 is it IPv4
Hi! I have a NetGear N600 Wireless Dual Band Router. I'm trying to connect wifi extender. I get all the way through, but when I click "finish" it says "IP is dif. Than root AP. Extenders support said ...
Sep 07, 2022Guru - Experienced User
What extender you are connecting to it?
What firmware is on the router?
firmware on the extender?
What method of setup are you using on the extender? some use wps, some use a installation assistant
Mz_G
Sep 08, 2022Aspirant
Hi! I purchased one off Amazon. It's a EITTAR 300 Mbps Wifi Range Extender. Router Firmware is V1.0.046.1.0.45. Extender Firmware.…... Honestly, haven't a clue how to obtain this information. Setup method....it came with instructions and I just followed the prompts. One of reasons I was sold is because it was supposed to be a "1-Tap Setup". Ha! My parents taught me better, "If it's sounds too good to be true, it probably is". Yet, here I am. Grown and still hard headed.
- plemansSep 08, 2022Guru - Experienced User
Were you trying to use the "one push button" method on it? (WPS)
Or did you try connecting to the extender and using its installation assistant?
Reason I ask is the push button method works great with the same manufacturer's but when you mix them, you can run into issues. Its where a manual setup works better.
- Mz_GSep 08, 2022AspirantI attached pic of quick setup guide I used. Hope this will help clarify. I would think this way isn't what the call 1 tap setup, but then again this is all foreign to me. Sorry, I'm not very helpful. Thank you for your patience, and willingness to try to help me with this!
Are you using any special characters or spaces in the primary routers ssid or password?
If so try removing them. Where does it fail exactly in the process?
I'd also try doing it on a pc and not using a phone.
