putter63
Jan 28, 2022Guide
WNDR 3400v2 Genie Utility software availability since it has been taken out of use?
I live in a rental house and the router is upstairs in someones else's apartment. My home PC crashed and I had to reinstall everything. I tried to reinstall the Genie utility but its no longer suppor...
- Jan 30, 2022
If that took care of it, you can mark it solved so others aren't trying to "fix it" as well. :)
Jan 29, 2022Guru - Experienced User
Do you need it?
You can manage the router through its ip address
You can download it here under the OS of your operating system:
genie | Product | Support | NETGEAR
- putter63Jan 29, 2022GuideI used to know how to find the IP Address for my stuff but I can't remember. Can you walk me through please?
How do I access the router settings using the IP Address?
Thanks in advance!- plemansJan 29, 2022Guru - Experienced User
you can try and type routerlogin . net
or if you pull up a command prompt on your computer, you can type ipconfig
If you're not in a double nat, the default gateway will be the routers address.
How to Find Your Router’s IP Address on Any Computer, Smartphone, or Tablet (howtogeek.com)
Awesome. Got it. Thanks for your help!
