putter63
Jan 28, 2022Guide
WNDR 3400v2 Genie Utility software availability since it has been taken out of use?
I live in a rental house and the router is upstairs in someones else's apartment. My home PC crashed and I had to reinstall everything. I tried to reinstall the Genie utility but its no longer suppor...
- Jan 30, 2022
If that took care of it, you can mark it solved so others aren't trying to "fix it" as well. :)
putter63
Jan 29, 2022Guide
I used to know how to find the IP Address for my stuff but I can't remember. Can you walk me through please?
How do I access the router settings using the IP Address?
Thanks in advance!
Thanks in advance!
Jan 29, 2022Guru - Experienced User
you can try and type routerlogin . net
or if you pull up a command prompt on your computer, you can type ipconfig
If you're not in a double nat, the default gateway will be the routers address.
How to Find Your Router’s IP Address on Any Computer, Smartphone, or Tablet (howtogeek.com)
- putter63Jan 29, 2022Guide
Awesome. Got it. Thanks for your help!
- plemansJan 30, 2022Guru - Experienced User
- putter63Jan 30, 2022GuideI've looked but can't find the button "Fixed" to click so that other members see that my issue has been resolved.
Can you help?
- putter63Jan 30, 2022GuideFixed. Thanks!
