shobi4
Oct 18, 2015Aspirant
WNDR 3400v3 unable to connect to ISP automatically after Firmware upgrade
After upgrading Firmware Version to 1.0.0.48 I am unable to automatically connect to ISP via PPPoE setup, using Login Info.. I am forced to use, no login required during setup and each time logg...
- Oct 20, 2015
For your "Connection Mode" set it to Always On.
If this still does not work, kindly post a screenshot of that window you're getting.
By the way, have you tried resetting the router after firmware upgrade?
If you have not, kindly push the reset button on the router for 10 seconds with a paperclip.
After resetting, reconfigure the router.
Let us know what happens.
