shobi4
Oct 18, 2015Aspirant
WNDR 3400v3 unable to connect to ISP automatically after Firmware upgrade
After upgrading Firmware Version to 1.0.0.48 I am unable to automatically connect to ISP via PPPoE setup, using Login Info.. I am forced to use, no login required during setup and each time logg...
- Oct 20, 2015
For your "Connection Mode" set it to Always On.
If this still does not work, kindly post a screenshot of that window you're getting.
By the way, have you tried resetting the router after firmware upgrade?
If you have not, kindly push the reset button on the router for 10 seconds with a paperclip.
After resetting, reconfigure the router.
Let us know what happens.
ElaineM
Oct 20, 2015NETGEAR Employee Retired
shobi4
Oct 27, 2015Aspirant
ElaineM: Thanks a LOT :catvery-happy:
Initially:
I configured it after resetting once the Firmware was flashed. ("As per the advice of the Support Technician", That was the first thing she wanted me to do once the firmware was updated.)
I ran the setup wizard. Initially when the connection was not connected. The Wizard did not recognize the type of connection.
The Tech adviced me to go to the ISP Portal and login manually. And it doesnt work automatically to connect.
I reached out to the forum thinking there could be other's who had a similar mishap after the firware upgrade.
After your last post, yesterday i ran the wizard once again (This time the internet is connected via visiting the ISP's portal). Here it recognized that my ISP is on PPPoE and requires username/password and it asked me to fill the form. After doing these and changing the ISP option to stay connected always from Dial On Demand, the connection seems to be stable now and working without a glitch.
PS: I apologize for the delay in response, was not able to find time to try the steps necessary to give an update.
