ToddeSwe
Aug 08, 2015Guide
WNDR-3700v2 firmware change of gui!
Hi The firmware in my WNDR.3700 v2 before the last one available had another nicer GUI but was removed when the last update was flashed. Can someone tell me what was wrong with this firmware wit...
- Aug 15, 2015
The firmware that had the modern GUI was V1.0.0.36 and is no longer available for download. I'm running it with no problems and I, like you,prefer the Genie interface as opposed to the old style GUI in V1.0.1.14 The current firmware has no reboot router botton and is missing a few other options that were in 1.0.0.36. If you would like 1.0.0.36 let me know and I could post if for you.
ElaineM
Aug 12, 2015NETGEAR Employee Retired
Hi ToddeSwe,
What firmware version you are referring to? From firmware version to what version?
ToddeSwe
Aug 12, 2015Guide
The version before V1.0.1.14 i don't have the versionnumber of that one but i know it was the version before the one i have now because i've just updated twice that one i speak of and from that one to this one i have now. :) Do you follow?! :) he he he
- ElaineMAug 14, 2015NETGEAR Employee Retired
ToddeSwe According to engineering, there is nothing wrong with the firmware. They just updated the smart wizard GUI to take advantage of additional features and consistency the product.
Regards,- ToddeSweAug 14, 2015Guide
No there's nothing wrong with it but the gui changed to a more nicer one for a while then it went back to where it is now.
- mbob4568Aug 15, 2015Guide
