M4ch1n3
Aug 08, 2015Aspirant
WNDR 3700v5 disconnect after 5min in games
Hi, I own a Netgear WNDR 3700v5 since 3 weeks. Got the latest firmware on it V1.1.0.30_1.0.1 I have the problem that i get disconnected at World of Tanks and Call Of Duty 4 after exactly 5 m...
- Aug 11, 2015
Hi M4ch1n3,
Welcome to the community!
Since you are using the LAN/cable connection, try enabling QoS. See if this will help eradicate the concern you are having. If it gives you the same result after enabling QoS, check your MTU setting. Let us know what happens.
ElaineM
Aug 11, 2015NETGEAR Employee Retired
Hi M4ch1n3,
