M4ch1n3's avatar
M4ch1n3
WNDR 3700v5 disconnect after 5min in games
Hi,    I own a Netgear WNDR 3700v5 since 3 weeks. Got the latest firmware on it V1.1.0.30_1.0.1   I have the problem that i get disconnected at World of Tanks and Call Of Duty 4 after exactly 5 m...
  • ElaineM's avatar
    Aug 11, 2015
    Hi M4ch1n3,
    Welcome to the community!
    Since you are using the LAN/cable connection, try enabling QoS. See if this will help eradicate the concern you are having. If it gives you the same result after enabling QoS, check your MTU setting. Let us know what happens.
    Determining optimal MTU size
    Changing MTU setting
