Webster46
Dec 21, 2020Follower
WNDR 4000
I cannot login to the old app for my WNDR 4000 looks like the app is not working since November 2020 so what app can I use and that place
Dec 21, 2020Guru - Experienced User
I usually prefer to just use the browser. Tends to be more accurate and faster.
Which app specifically were you using?
What device is it on?
- wcalifasDec 24, 2020Prodigy
Just use your laptop or browser on your cell phone and type 192.168.1.1 or http://routerlogin.net. The user name should be admin and the password will be password if you never changed its default login to your router.
