Webster46
Dec 21, 2020Follower
WNDR 4000
I cannot login to the old app for my WNDR 4000 looks like the app is not working since November 2020 so what app can I use and that place
Dec 21, 2020Guru - Experienced User
I usually prefer to just use the browser. Tends to be more accurate and faster.
Which app specifically were you using?
What device is it on?
wcalifas
Dec 24, 2020Prodigy
Just use your laptop or browser on your cell phone and type 192.168.1.1 or http://routerlogin.net. The user name should be admin and the password will be password if you never changed its default login to your router.
