Noonian's avatar
Noonian
Follower
Feb 02, 2018
WNDR 4300 wireless speed download 2.56/upload 4.59 How can I make it better?
  • Hi Noonian,
    1. What is the firmware version of the router?
    2. What is your subscription speed from your ISP?
    3. What speed are you getting when connected straight to the ISP's modem?
    4. What speed are you getting when wired to the router?
    5. Have you tried resetting the router?
    6. Have you tried changing the wireless channel?
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Noonian,
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Noonian,
    I would like to follow up and check if you are still experiencing the issue.
    Dexter
    Community Team
