Mchevrier1
Apr 05, 2018Aspirant
WNDR 4500 Can't connect to network drive \\readyshare\USB_Storage with Win 8.1
My Router WNDR4500 Firmware V1.0.1.46_1.0.76 OS on PC Win 8.1 Pro The router sees the device (shows the right size and volume name) but when I go in File Explorer to connect to a network drive...
- Apr 16, 2018
I used your first sugestion/question and got to work. See the joined picture.
Thanks
DexterJB
Apr 15, 2018NETGEAR Moderator
Hi Mchevrier1,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Mchevrier1
Apr 16, 2018Aspirant
Thanks
