St-Domo
Sep 15, 2020Follower
WNDR 4500 halves data transmission WAN to LAN
My Kabel IP-Provider has increased WAN data transmission from 300Mb to 600Mb. At the LAN ports are max. 350Mb.
Is there any explanation?
should be able to go faster.
I'd start with a factory reset.
Also make sure traffic monitoring, access control, parental controls, and qos are disabled.
1 Reply
