youni
Sep 28, 2016Aspirant
WNDR 4500v2 Randomly Stops Accepting Login Attempts
I currently have a WNDR4500v2 set up in AP mode and everything is working fine. After about 2 weeks, I noticed my network speed has dropped significantly. I found that the issue is from the WNDR450...
- Oct 25, 2016
Well, I finally had a chance to reflash about 2 weeks ago. So far everything is working well. There's been no slowdown or unable to log in issues. I guess reflashing helped me in this case.
ElaineM
Sep 29, 2016NETGEAR Employee Retired
Hello youni
Welcome to the community!
It's always best to have a static IP address on the router once you have configured it in AP mode.
One possible reason why it's unreachable is that it may need software update.
The behavior that it is showing right now is pretty odd. You can ping but you cannot access through a web browser. Have you tried using a different browser?
I would suggest to upgrade the firmware or if it already has the latest one just reflash it by re-uploading then reset the unit. Once you have reset, you will then reconfigure once again the unit to the way it was then that should fix it.
Retired_Member
Sep 29, 2016The problem as I recall was with most WNDRXXXX where the AP Mode option Wasn't part of the Original FW it was added several years later and never worked correctly at least this was the case with WNDR3700 & WNDR4000 and apparently the WNDR4500 too.
Like you suggested they became unreachable and required a reboot I honestly cannot remember if I tried address reservations But I do remember being given a beta FW for the 3700 AP mode. By the time the 4000 ap mode came out I gave up on it.
