rtbala
Feb 05, 2022Aspirant
wndr 4700 connect telnet
Hello. I need to telnet to my WNDR 4700. The firmware version is V1.0.0.56. To do this, I downloaded telnetenable.exe and used it. The port scanner shows that port 23 is open. But when using the "...
Mar 05, 2022Guru - Experienced User
Any progress on this?
But when using the "telnet ip address of the router" command,
the connection does not occur. Please help me to connect.
