stwjn
Jun 22, 2016Aspirant
WNDR3300 - do I have V1 or V2? (pic attached)
Want to make sure we are downloading the correct firmware for this router. How do we tell if it is V1 or V2?
- Jun 22, 2016
@stwn If it's version 1, it will just indicate the model number itself, otherwise it will include a small v and a number to indicate which hardware version.
TheEther is also correct, you may check the firmware version to verify which model version it belongs to.
ElaineM
Jun 22, 2016NETGEAR Employee Retired
stwjn
Jun 23, 2016Aspirant
Thanks to both of you. I am trying to help a friend remotely, so was trying to get as much info as I could before saying "do these steps".
Appreciate it!
- wcalifas831Jun 23, 2016Prodigy
You definitely have version 1 of the wndr3300
