MrShelby
Aug 08, 2021Follower
WNDR3300 and Gigabit switch GS308 will it get the network speed which i'm getting from the Modem
I'm going to Buy the gs308 gigabit switch and i have a doubt that,the switch will give the Router(WNDR3300) the original speed. I'm have a 200mbps broadband connection and in that modem there's onl...
michaelkenward
Aug 09, 2021Guru - Experienced User
The WNDR3300 is an ancient (2007) router. According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN support on the WNDR3300 is only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware.
Your router will never give you the 200 Mbps you are paying for.
MrShelby wrote:
I'm have a 200mbps broadband connection and in that modem there's only 1 ethernet port i would like to extend that connectionfor that i need the switch,
What is that modem? Do you know that it supports Gb LAN? If it is as old as the router, it may also be stuck at 100 Mbps.
Any switch you buy has to come after the router if the idea is to connect other devices to the Internet. Even a Gb switch will go no faster than your router can deliver. Only a new router can do that.
