rhinterberg's avatar
rhinterberg
wndr3400 ap channel limitations
Using an App called wifi Analyzer, it tells me that ch. 14 is the best channel to use, also shows no one else is using that channel, but trying to assign ch 14 thru the geni the channel list only goes up to 11. Why can't I see channels 12,13 & 14 in the genie ? Is there a firmware upgrade that will allow me to use ch 14?
