Solvenet
Dec 29, 2023Aspirant
WNDR3400 as ethernet switch paired with T-Mobile gateway (2023) TMO-G4AR
Greetings. Recently joined T-Mobile home internet (it was good deal). T-provides a gateway that only comes with two ethernet output ports. For security reasons, I prefer to use wired connection ...
microchip8
Dec 29, 2023Master
In which mode is the NETGEAR device? Router or Access Point? If you're piling up router after router, it can reduce the throughput
Solvenet
Jan 01, 2024Aspirant
Appreciate the question of router vs. access point.
QUESTION: Where do I find? Went to routerlogin.net, got into the router and could not pinpoint where to see it. Appreciate your help.
- michaelkenwardJan 01, 2024Guru - Experienced User
Where do you find what?
This?
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
Something else?
There is always the manual.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.- SolvenetJan 01, 2024Aspirant
Thank you. From another community, it seems Netgear took away the "access point" option from the WNDR3400v2.
Anyone, please, know a workaround to be able to convert the Netgear WNDR3400v2 into an Access Point? thanks.
- michaelkenwardJan 02, 2024Guru - Experienced User
That's interesting. Where can we find that "other community"?
What happens when you try to follow the instructions in the manual for your device?
Support | NETGEAR
Check the section in the manual Advanced Wireless SettingsThe WNDR3400v2 is so old that it predates the official instructions:
But I have never seen any suggestion here that Netgear has made it impossible. AP mode is a basic function of routers.
Select Advanced > Advanced Setup > Wireless Settings
What firmware is installed on your router? If Netgear did disable AP mode, you can always go back to an older version that still supports that.
