mattmer
Dec 31, 2021Tutor
WNDR3400/n600 v1 see ip camera on device list, cannot access
OK. I purchased an Ebay ip camera (360° Panoramic WiFi IP Camera E27 Light Bulb 1080P HD Wireless Security Camera | eBay). Cannot seem to connect to it. I've tried the ip address i see in the router ...
- Jan 08, 2022
The velop. All is working ok now. I got the camera added and installed. Just kept resetting the camera and trying. All so confusing.
michaelkenward
Jan 01, 2022Guru - Experienced User
The original WNDR3400 is pretty old, from 2010. So it isn't really geared up for the onslaught of Internet of Things (IoT) toys that have appeared since then.
But, as plemans says, you should start with the camera. The router just puffs out wifi. It is then down to the camera to play ball.
Cannot seem to connect to it. I've tried the ip address i see in the router (10.0.0.7), but nothing.
If your router has given itself that address, rather than the default of 192.168.1.1, I'd look for a modem/router on front of it. If so, you can expect trouble.
What is Double NAT? | Answer | NETGEAR Support
