Jbw's avatar
Jbw
WNDR3400V1 CAN FIND FIRMWARE FILES
WNDR3400V1 I have tried to upgrade the firmware on my N600 through the web interface, download zip and the files don't seem to be avalible. 404 file not found, and download doesn't start. Had to reset...
  • TheEther's avatar
    TheEther
    Feb 20, 2016
    You can download firmware directly from downloadcenter.netgear.com, although it appears to be down at the moment.  The site is out of disk space.  :smileyembarrassed:
