JohanVar
Dec 01, 2020Follower
WNDR3400v2 - cant change 5ghz to WPA2-PSK
Firmware: V1.0.0.54
Hey, as said:
I can't change the security for 5Ghz Network to WPA2-PSK. When I chose it in the interface and on hitting *Apply*, i see it switching back and the page reloads and nothing has changed, still WPA-PSK, not any feedback on why.
Doesn't matter on which device i try.
No Idea what to do. Any help appreaciated.
Thanks
- olympos1625NETGEAR Employee Retired
Hi JohanVar,
Good day!
Welcome to NETGEAR Community!
First of all, we do apologize for the inconvenience of not getting back to you immediately due to the backlog in the system. Do you still have the issue? Have you tried using another device to change the wireless settings? Have you tried downgrading the firmware then reset the router and reconfigure?
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
- wcalifasProdigy
Try doing a hard reset on your router by pressing the reset button with a paper clip for 30 seconds while powered on and see if that helps.
