Art_C
Nov 12, 2015Tutor
WNDR3400v2 Access point setting GONE.
I believe this may be a bug in the new firmware I just installed in the router. It was setup as an Access point before the upgrade. It is still correctly setup after the upgrade. The problem is th...
- Nov 13, 2015
Thank-you for the timely response.
I have learned a few things and just wish to note them here for others future reference.
1) AP Mode is not available for the --51- update. It has been removed, but the reason is an error (or memory requirement...), rather than security.
2) In standard AP mode, ALL security IS available. Only if put in base or repeater mode does security drop to WEP Only.
3) Strangely, the base and repeater modes still showed up as available, though not accessable due to no AP Mode. (Solid Bug. No Matter. Old Firmware is Fine.)
4) The basic AP Mode is mainly useful if this unit IS NOT the device doing direct DNS searches. I needn't get into details, but without AP mode, it won't work well as an Access point.
5) The new update DOES offer better access control, and for normal home use might be desirable for those functions. IF a Basic AP add-on, don't bother with update.
As a strange little note: This unit was in AP mode after the upgrade. It actually noted this on the "Start" page, however it dropped into normal mode all by itself after a few hours. I was not watching during the time it changed, but there was no power cycle nor reset done. It did it by itself. It did NOT change the IP, which confuses me a bit as the AP IP is not stored in the same location as the IP when in normal router/gateway mode. Very interesting. Possibly the same internal memory location used, but I'm not about to decompile to find out. I just reloaded 38 firmware.
Thanks again for the ideas. After "downgrading" to the "38" version of firmware, all is fine and I get good 5G connections in AP mode. This really gives me more reason to follow the old addage of "If it ain't broke, don't fix it." If the software writers could put basic AP mode back, and remove the Base and Repeater modes to fit it, then THAT is an update I would like as the access control for wireless devices is a great little option to have. For now, the original "38" firmware works fine and I'll just wait and see what happens.
netwrks
Nov 12, 2015Master
After the firmware upgade, did you reset to factory default? If you did not, you should, and try again. After every firmware upgrade, just reset to facotry. It saves hours of work / frustrations. That way you will know what the story is with any firmware..
- Art_CNov 12, 2015Tutor
Thanks, but that was the entire point of the post.
If the missing option remains missing then the unit is no longer useable for it's current application. If the reset changes the setup page, then all would be OK. I find it unreasonable to risk the functioning of the unit just to see if that corrects a possible setup page error.
This is why I asked if anyone had run the firmware update (I would hope so....) and could see if the option for "Enable Access Point Mode" shows up. If it does, no problem, I will immeadiately reset. If not, I cannot reset without scrapping the unit for it's current function. (I'm talking about more than 1 unit in the near future.)
At this time, I am wondering if I can "Downgrade" these units to older firmware. If that is possible (Which I will assume IS possible unless I hear otherwise within a day or so...) then I will take the chance, reset the unit, and if the option doesn't appear then just downgrade and turn said option back on, then upgade again. Complex, but workable.
Either way, thanks for the reply as it made me think of other options which I can attempt myself if no-one has seen this before.
