shan9203
Jul 31, 2015Aspirant
wndr3400v2 and chromecast
I recently had some wifi issues so I called Netgear support and the gentleman was very helpful and got me up and running with a new wifi password and renamed my home network among other things. He ma...
- Aug 01, 2015
Chrome cast will only work on the 2.4 wifi
wcalifas831
Jul 31, 2015Prodigy
Well if you say that you changed your network name and the password you have to go to the chromecast networks available and select the new name of the network and use the new password to join the newly named network.
- shan9203Aug 01, 2015Aspirant
Thank you but in order to change those setings on the Chromecast I ned to be able to connect to it first which I cant because I get booted off the wifi network. Make sense? I am convinced it is a router setting that is making the wifi signal to drop when I try to set up the Chromecast.
