JWHIII
Nov 03, 2015Tutor
WNDR3400v2 "AP mode" switch missing after firmware update to 1.0.0.52
AP mode switch used to be under Advanced- Advanced Setup- Wirless Settings. It is no longer there. The articles I have found while searching the Netgear site say it will auto detect that it is behind...
- Nov 04, 2015
Use LAN to LAN instead of LAN to WAN.
ElaineM
Nov 04, 2015NETGEAR Employee Retired
Welcome to the community, JWHIII
Latest firmware does not support Wireless Repeating functionality.
NETGEAR has removed the repeating functionality due to security vulnerability since it will only allow you to use WEP.
The only way to get it back is to use the previous firmware that supports it.
- JWHIIINov 04, 2015Tutor
Access Point mode has nothing to do with wireless repeating, and the latest firmware added wireless repeating functionality that wasn't there before. Since firmware update, the WNDR3400 insists on being a router and having seperate WAN and LAN subnets even though it is behind another router and firewall. This makes it worthless to me since the update and I will be replacing the firmware with older version from netgear or DD-WRT.
- ElaineMNov 04, 2015NETGEAR Employee Retired
I apologize about that.
You may want to just disable the DHCP server of the router and assign a static IP under Advanced > LAN Setup
This is the same as AP mode.
