JWHIII
Nov 03, 2015Tutor
WNDR3400v2 "AP mode" switch missing after firmware update to 1.0.0.52
AP mode switch used to be under Advanced- Advanced Setup- Wirless Settings. It is no longer there. The articles I have found while searching the Netgear site say it will auto detect that it is behind...
- Nov 04, 2015
Use LAN to LAN instead of LAN to WAN.
ElaineM
Nov 04, 2015NETGEAR Employee Retired
Drencor
Dec 07, 2015Initiate
Personally this issue should be directly addressed by the firmware development team. Since this option was technically a selling point for this router to be used as a AP and have 4 usable Gigabit Ethernet ports along with the WAN port being used as the uplink port to the rest of the network.
Removing a key feature is not a good idea as one many people take this as a bait and switch. Get a customer to buy a product and then remove key features/usability of the product.
As the firmware 1.0.0.52 removed the AP Mode it also removed "Wireless Card Access List" which was just below the AP mode area. Which a lot of security people as a second layer of security also add in the allowed devices into this area as well.
Please pass on to the development team to restore "AP Mode" and "Wireless Card Access List".
Thank you.
- ElaineMDec 07, 2015NETGEAR Employee Retired
I'm afraid that there will be no engineering resource that will be working on a firmware update.
There will be no future updates expected for this WNDR3400v2.
