Rodrimag
Jan 15, 2023Aspirant
WNDR3400v2 how many devices can connect
Hi I have several IoT (Smart switch, smart outlet) and the total of devices is 42 itens. My main router is R6350, this router is reposible to give all IP number and I have more 2 router in AP mode, o...
- Jan 16, 2023
Rodrimag wrote:
As I had 2 old routers, TP-link TL-WDR4300 and WNDR3400v2, I connected these 2 devices as AP, and now the network is stable
Perhaps that is because they are in better positions to feed the devices. WiFi has a limited range.
How big is the space you are trying to fill with WiFi?
You seem to be trying to cobble together a network with a grab bag of old and ancient basic devices that were designed before the rush in to IoT stuff. Throwing in yet another strange and aged device, the WAC104 isn't going to bring you nearer to current technology.
If things are working as you want, why not just keep adding stuff until you hit the ceiling? Then rethink your network.
Rodrimag
Thanks,
The connections are wireless, I have only 5 wired devices.
I am thinking to buy the model (NETGEAR Wireless Desktop Access Point (WAC104) - WiFi 5 Dual-Band AC1200 Speed | 3 x 1G Ethernet Ports | Up to 64 Devices | WPA2 Security | Desktop | MU-MIMO | Supports 3 SSIDs | 802.11ac) the price looks good at amazon $29.90.
So, Can I define this model as main main router , it means the modem connect with this model (WAC104), and this device connect my current R6350 as AP mode?
Br.
Rodrigo
michaelkenward
Jan 15, 2023Guru - Experienced User
There may be good reasons for that low price.
The WAC104 bills itself as a "Wireless Access Point" (AP) it is old (2016) and while it does have some router features the manual goes into great detail on how to get it to work with your router. That's what it was designed for.
It might make a great AP, it seems like a quirky thing to choose as a router.
What is wrong with using your R6350 as your main router? It is actually younger (2018) than the WAC104.
Why are you looking for new hardware? What do you want to so that you can't do now?
If it is the wifi clients, try the R6350. If it causes problems, look for something else. Or, at that price, buy an WAC104 and use it as an AP behind the R6350.
- RodrimagJan 16, 2023Aspirant
HI,
I didn't know about the details of the WAC104. Thanks to explain.
My problem is when I use only the R6350 my smart devices are unstable losing connection and impossible to register new ones.
As I had 2 old routers, TP-link TL-WDR4300 and WNDR3400v2, I connected these 2 devices as AP, and now the network is stable, my main concern is to know how many devices the tp link model and WNDR can handle, as the WNDR is an old model is not easy this kind of information and the TP-Link is the same challenge.
I have plans to add more smart devices, but I don't know how many devices I can add to my network, If I know how many devices each router can handle, I can divide better between them.
- michaelkenwardJan 16, 2023Guru - Experienced User
- plemansJan 16, 2023Guru - Experienced User
Basically michaelkenward is saying you're trying to piece this together with old products that are generations behind.
Never a good plan for speeds/stability.
It might be time to scrap it and upgrade a bit. You can pick up pretty cheap mesh systems on amazon both new and renewed.
If you've got a hardwired backhaul the dual band systems can perform perform pretty well. Like the MK nighthawks. Or you can pick up a triband system and use a mix/match of wired and wireless backhaul.
