lakota
Sep 02, 2015Aspirant
WNDR3400v2 not coming back on
I tried to hook up to a wireless printer using my WNDR3400v2 to my girls school computers at a foil and know their computer's don't even have my WNDR3400v2 router as an option on the wifi connection ...
- Sep 05, 2015
From your description it seems that both the 5GHz and 2.4GHz bands have been disabled, try pressing the wireless on/off button at the rear of the router, give it a single press then wait a minute or two to see if anything changes. See the manual pages 11-13;
http://www.downloads.netgear.com/files/GDC/WNDR3400V2/WNDR3400v2_UM_23JAN2013.pdf
lakota
Sep 05, 2015Aspirant
Yes i have, and unplugging, waited and replugged from cables and ele., but from your statement, i do see that there are two lights not lit any more; the long ones.
The top light is lit, the check-slash-G, the 2nd one is lit; the circled globe, the next two are not lit; long thin lights. then the numbers 1, 3 and 4 (my PC, and old PC and the roco box) are also lit and all working fine.
Babylon5
Sep 05, 2015NETGEAR Employee Retired
- lakotaSep 05, 2015Aspirant
Thank you so much i did not even see that little button on the back, just kept resetting the big one over and over. Again thank you.
- Babylon5Sep 05, 2015NETGEAR Employee Retired
Well if you’re unfamiliar with these things then that’s quite understandable, all sorted now then.
