Belljon
May 09, 2016Aspirant
WNDR3400V2 (RN600) router - wireless repeating with Arris Wifi Modem
I need help. I have an Arris wifi Modem (TG862) - recently installed when moving to a new house and signing up for cable internet.I am having trouble with weak wifi signal in the back bedrooms - with...
- May 11, 2016
In order to boost the signal on the desired location, run a long ethernet cable from the modem to the NETGEAR router.
Again, there's no way for these 2 devices to be wirelessly connected to each other.
Belljon
May 11, 2016Aspirant
Thank you for the answer. I was under the impresison that the N600 could be used as a repeater/extender but you are saying this is not possible? So the options are to increase cable length or get a booster for the Netgear. What about using it as a different network but connected wirelessly to the wifi modem?
ElaineM
May 11, 2016NETGEAR Employee Retired
In order for the modem and NETGEAR router to be connected wirelessly, they should both have WDS capability.
Which most modems doesn't have. WDS is an old feature where you can set the router to be in repeater mode but then it will give you less wireless security.
WNDR3400v2 has that WDS feature but then the modem doesn't have so it will not work.
Regarding the different network, can you elaborate further on how you want to achieve it?
- BelljonMay 11, 2016Aspirant
Thanks for that. At the moment, my Netgear is connected to the Arris via ethernet cable. So I am currently using the Netgear connection - but the Arris is available as well to connect to directly via my wifi network options.
Am I then able to connect the Netgear wirelessly (similarly asI have it now, just wireless) to the Arris in the weaker area of the house - and then connect to the Netgear connection in that part and the Arris connection in the other? Dont know if this makes any sense.... : )
- ElaineMMay 11, 2016NETGEAR Employee Retired
Ok...appreciate your help. Thank you....
