mrg9999
Sep 27, 2015Tutor
WNDR3400V2 (RN600) router - wireless repeating
First posting ;) I have this router, firmware V1.0.0.52_1.0.81 .That I either use as my internet router connected to a cable modem, or as an access point, switch, readyshare. I would like to ena...
- Sep 28, 2015
Hi mrg9999,
Welcome to the community!If the router is used as a Wireless Repeater, most of the router features will no longer work such as the USB Readyshare.
The configuration settings will also be inaccessible too unless you reset.
You can only take advantage of the feature if you use the router as a Base Station.
Hope this helps.
ElaineM
Sep 28, 2015NETGEAR Employee Retired
Hi mrg9999,
Hope this helps.
